Mugs
jamescork2
Re: Mugs
I have just bought some Latte mugs and downloaded the template which has been done in Adobe. Could anyone tell me how I get the picture in the template as I am not sure. Or is there any other way of printing so that when I put the paper on the mug it will print OK. Thank you Jim.
- Has thanked: 11 times
- Been thanked: 9 times
Re: Mugs
Do you have an outline in something like Coreldraw? You may find that you need to warp the image a little so that it looks right on the mug, just very slightly.
Re: Mugs
You should be able to bring an image into the template or set the image so it is behind the White mask layer ( try sending the image to back in the layers).
Alternatively print the picture as normal and position on mug by eye. Depends what image you have for best approach.
Re: Mugs
is this template got cut out area??
jamescork2
Re: Mugs
Hi Paul, yes in Adobe it has a chequered area and an outline of the mug i.e. narrows at the bottom and larger at the top.
Re: Mugs
ok. If you go to my website members area there you can download pdf or video how to work with templates like this.
jamescork2
Re: Mugs
