do you know any free program for vinyl cutting ??
Any OS, software in here.
kris_hm
Re: do you know any free program for vinyl cutting ??
Post by kris_hm »
Hi,
As question above.
I've just bought my first vinyl cutter. Seller can supply with "One Year SignCut Pro" for additional £. But I would prefer some free software if possible. I have Corel Draw x4 but heard it's hard to cut straight from Corel.
Any suggestions??
John G
Post by John G »
You can get a plug in for corel but i've never used it - I just use artcut that came free with the plotter.
SignBlazer Elements
its trial forever as it is not developed any more as guy died or something. you can use it over and over again. very powerful.
kris_hm
Post by kris_hm »
Thank you Paul. I'll definitely give it a try :)
forgot to mention that you can use it for countour cut too ;)
DS Designs
Post by DS Designs »
Coreldraw is a piece of cake with a vinyl cutter...it's all I use
mrs maggot
Post by mrs maggot »
ds, do you use a plug in for the corel and what version of corel do you use ??
i use signblazer, the counter can be a bit of a pain, there is supposed to be a way of downloading it without the counter, but whenever i have tried re-installing it i still get the counter, so it must have some hidden files that stay on your pc even when you remove and reinstal
I've used the plug in before, simple and works a treat. Unfortunately the download doesn't appear to work and they don't respond to emails :-(
GoldRapt
Has thanked: 6 times
Been thanked: 8 times
Post by GoldRapt »
Signblazer is still available here
http://support.uscutter.com/index.php?/ ... r-software
What's the plug in exactly?
regards
Tony
-launching july/august 2026
Market Mik
Post by Market Mik »
mrs maggot;27273 wrote:ds, do you use a plug in for the corel and what version of corel do you use ??
Hi Mrs Maggot,
If you go here http://forum.uscutter.com/index.php?/fo ... ignblazer/ and have a look around you will find the files to install to stop the counter and the trial screen.
