Check your waste tank and reset it!
Re: Check your waste tank and reset it!
Hi All! Iam sure i dont need to tell you how important is to know how far is our waste ink tank full up. In case you in the middle large job you can see your printer is flashing with red lights. what to do??? RESET IT! is not the magic cure (well... it is :tongue:) as you need to epmpty your waste tank anyway but at least you can finish your order.
SO here it is.
Software that can reset it for you. Software is free for download. Most function is free to use. Only reseting function to be enabled you need to buy a KEY. but it only cost $9.99 so I dont think you can go wrong if you realy need it ;)
you can download from HERE
Hope you can find good use for this software.
PS! Even if you dont want to reset your ink waste tank counter its worth to instal this software as it can tell you (free) how far you are with your waste counter ;) so you can get preperred ;)
All the Best
PAul
Lee
Post by Lee »
does a richoo 3300 have a waste tank?
I think all inkjet have it. But this software is for epson.
R.Prints
Post by R.Prints »
SSC UTILITY has reset functions for most Epsons and is free.
SSC utility is odl and dont support smaler A4 printer and do not support B1100. Not when I try it.
smitch6
Post by smitch6 »
does this software support mac's?
dont know :) but is worth to ask them :) any way. you can instal it on your wife laptop and then reset it
its not every day use software.
