EPSON 1400 settings
4binlids
Re: EPSON 1400 settings
Post by 4binlids »
Can anyone tell me what settings I should be using (print quality / paper etc) as a starting point on Epson 1400 please?
starting point is:
paper type: mate
print quality: photo
ICM: thicked
icc/profile/collor correction/colormenagmen: OFF (so many choices as iam not sure what one is in your printer driver)
4binlids
Post by 4binlids »
Ah! Just the man! Where do I find the ICM and icc profile settings please?
I'll tell you what it is - colours all print really well but don't have the real vivid hues in which they were painted. I need to get the colours brighter and more obvious. Will post some photos of original illustrations and the prints. Thanks
4binlids;38024 wrote:Can anyone tell me what settings I should be using (print quality / paper etc) as a starting point on Epson 1400 please?
Everything is available to download here:
http://www.sawgrasseurope.com/technical ... /artainium
4binlids
Post by 4binlids »
Thankyou Martin. I'm a REAL technophobe and am totally computer illiterate! What do I do with that file apart from download it? Thankyou
you should get all on the cd. Just cllick right buttom on your icc file and then click on "instal profile"
The other question is what inks are you using?
ICC profiles are dependent on your ink set, and so you may not have great results using an Artainium ICC if your inks are different.
4binlids;38032 wrote:Thankyou Martin. I'm a REAL technophobe and am totally computer illiterate! What do I do with that file apart from download it? Thankyou
Download and run the file. It's an exe file so installs automatically once you finish registering.
alright :rolleyes::redface: so is not only icc download then????
Paul;38052 wrote:alright :rolleyes::redface: so is not only icc download then????
basically yes, but wrapped up in a exe file and registration is required now to complete.
