hi my names matt, i recently bought a mug press package to start with with the intensions to go onto making other things like tshirts etc.
although ill probably purchase a better press first, mine keeps leaving slight fades at the bottom of my images :redface:
hi
- DS Designs
Re: hi
Welcome Matt, it's going to take a few wasted mugs until you get the correct time and temperature, start off at 180c for 180 seconds and see how it comes out
Dave
Dave
Re: hi
Welcome Matt - the fade at the bottom may be because you mugs bevel at the base. Try leaving 3 or 4mm gap top and bottom and see if that helps.
Re: hi
bms;38704 wrote:Welcome Matt - the fade at the bottom may be because you mugs bevel at the base. Try leaving 3 or 4mm gap top and bottom and see if that helps.
worked thanks
