t shirt printing
jase121
Re: t shirt printing
Post by jase121 »
hi i already do mug printing and have decided to give t-shirt printing a go i was just wondering what i would need & if there is some where i can get the products from cheap. as i am only looking on ebay and that does not leave much for profit
thanks for any help
John G
Post by John G »
If you're already sublimating, get a heat press and use sub t shirts. If you're on a tight budget then it'll definitely be ebay as good quality (named) heat presses are an arm and a leg!
jase121
Post by jase121 »
ok thanks can i use any type of cotton tops or does it have to state sublimation tops
jase121;41104 wrote:ok thanks can i use any type of cotton tops or does it have to state sublimation tops
Subimation garments aren't cotton. The inks won't bond with cotton and will look very faded.
Wherever you source your blank t-shirts from (whether a specific sublimation supplier or your local Primark) they will need to be polyester, and not cotton.
John G
Post by John G »
Basics of sublimation - you can only sublimate onto polyester or a high content of polyester.
jase121
Post by jase121 »
thanks for your help can i use the same paper of my mug printing for t-shirt printin
g
John G
Post by John G »
Yes you can but some papers offer a higher release which will give your colours more depth - not sure of the name of the best paper
jase121
Post by jase121 »
thanks for your help m8
