Vinyl not sticking
Re: Vinyl not sticking
I am new to this but how long do you press vinyl for.
I have tried my first attempt at 20 seconds then 30, 40, 60 ,60 but each time the vinyl seams to lift and stick could it be the type of tee poly or cotton but i thought i doent matter with vinyl?
I press mine at around 12-15 seconds.. what temperature are you using ??
Also, if you're using a cold peel and peeling whilst hot, that will remove the vinyl...
What make of vinyl are you using ??
entirely depends on the type of vinyl....unless you know what you are using and the required temp, pressure, time and hot or cold peel you'll be making mistake after mistake.
it is what i got when i bought the press, is there a way to tell if it is hot or cold peel?
why not ask whoever you bought it from what type of vinyl it is.........job done.
Bin it and buy some new, problem solved, as long as the heat press is working properly.
Scotty@BMS
Excellent point. You should check the temperature of your press with an infrared thermometer. It may well be telling you porkies as to what temperature it is really at.Bison 28;46699 wrote:As long as the heat press is working properly.
Could be a bit of a waste of time really Scott unless plugy knows just what vinyl is being used.Scotty@BMS;46700 wrote:Excellent point. You should check the temperature of your press with an infrared thermometer. It may well be telling you porkies as to what temperature it is really at.
