Vertical or Horizontal
Charlie_
Re: Vertical or Horizontal
Post by Charlie_ »
im in the process of now getting a mug press, the question is, horezontal or vertical?.
What your views I'd be interested to hear them, to help me decide.
Charlie
WorthDoingRight
Post by WorthDoingRight »
Well, it is all a question of gravity! I personally favour the horizontal presses as you have some flexibility in mug positioning and can slide larger items about if necessary and because I tend to have my sublimation paper overlap top and bottom of my mug I would prefer not to bend this in a vertical press. The vertical presses are obviously more consistant in positioning as gravity forces them to the bottom and you often have little stands that you put in the bottom to raise your mug up. I suppose however that the differences are minor and it is probably the controller that is the major difference between presses and often overlooked.
