Printing onto Subli Flock.
Earl Smith
Re: Printing onto Subli Flock.
Using genuine Ricoh R subli inks. What temperature should I print onto the flock? Too hot and the flock will toast and too cool and the print will wash out.
Artanium was 195 for 35secs.
- WorthDoingRight
BMS says 200C for 35-40 secs to transfer image to flock
BMS says 170C for 10-15 secs to transfer flock to item
Earl Smith
We do, but that's only for transferring the PRINTED FLOCK to the garment. The ink transfer is hotter and longer. Full instructions here:WorthDoingRight;53740 wrote:BMS says 170C for 10-15 secs
http://www.printerowners.co.uk/sublimat ... -flock.htm
- WorthDoingRight
Nope it seems Mr Wrong lolEarl Smith;53741 wrote:Thanks Mr Right.... ( Richard?)
Earl Smith
You are right , 170 is too cold.
I do it at 198 for 35 secs and it works. But the white areas are a little toasted. Not much but just a little off white. I asked the question because the Ricoh Gel is pressed onto mugs at 180.
Martin, in your Ad for the flock you said "We recommend you cut the image in reverse through the backing sheet of the sublimation flock first and then transfer the image afterwards." You should also point out that you have to weed the shape from the flock before pressing. Otherwise the glue will fuse it back together again.
Thanks for the info guys.
I had assumed that would be obviousEarl Smith;53940 wrote: Martin, in your Ad for the flock you said "We recommend you cut the image in reverse through the backing sheet of the sublimation flock first and then transfer the image afterwards." You should also point out that you have to weed the shape from the flock before pressing. Otherwise the glue will fuse it back together again.
Did you really mean to 'print' onto flock? If you did then being a complete ignoramus of the use of flock I would be interested because I didn't think you actually 'printed' onto flock.Earl Smith;53736 wrote:Using genuine Ricoh R subli inks. What temperature should I print onto the flock? Too hot and the flock will toast and too cool and the print will wash out.
Yes, well, you print to paper and heat press this into the flock to get full colour transfer.RogerC;54039 wrote:Did you really mean to 'print' onto flock? If you did then being a complete ignoramus of the use of flock I would be interested because I didn't think you actually 'printed' onto flock.
Thanks Martin....I knew I could rely on this place to 'edify' me.....bms;54041 wrote:Yes, well, you print to paper and heat press this into the flock to get full colour transfer.
