Anyone know of a good tote bag supplier, I need black and bright pink A3 and above , cotton or felt using
for rhinestones and vinyl
Tote bags
- mrs maggot
Re: Tote bags
most of the bigger suppliers stock them, be careful and always use a thick teflon sheet as they seem to scratch the surface of the press alot, i bought a 2nd hand press from someone who only printed tote bags and could not get over the scratching on the top of the press
Re: Tote bags
Thanks for that info mrs maggot, never though a cottom bag would scratch a plate, did they do rhinestones?
I have a thickish teflon sheet so will use that.
Thank you craig, ive ordered samples from a couple of companies, so ill see what they are like as i need a few hundred.
Re: Tote bags
Hi Viccar
I can get these for you, probably at a cheaper rate than other suppliers. PM me with quantity and colours and also if you want long or short handle. I have a few thousand in stock so should be able to spare a few hundred
Mine are the 5oz ones.
In the interests of the open forum you could try The Carrier Bag Shop & Westford Mill, both are very large stockists.
- mrs maggot
Re: Tote bags
i was amazed that it had scratched as well, but thats all they pressed on it, im wondering if it was more the nylon stitching rather than the bags themselves, cant remember which member i bought it from now, but you could see the scratches, all gone now thanks to hubby and some re-coat spray
