Hi
I have got some sublimation lighters but when i print on them the colour does not take. The supplier says 190 degrees for 180sec. The lighters are silver. Please any help will be appreciated.
Julie
printing sublimation lighters help
Re: printing sublimation lighters help
I printed my lighter 180C for 60sec. light pressure. looks good but on mirrored silver you can not see much. well. you wont as there is no white background
Printcess Jen
Hi, just out of interest how are you printing these? ie are they flat and you are just using a press or another attachment? I would be interested to know
I did a few hundred of these a while back. They were the white ones from BMS. I used 190 degrees for 120 seconds with a medium to heavy pressure and they printed lovely.
Done in a cheap clam shell heat press. Make sure you use an old heat blanket for the bed as the lighters make an impression on the bed which will not come out.
