Eliminating the permanent crease mark from your paper edge
Share your hints and tips with other members
sharyn
Re: Eliminating the permanent crease mark from your paper edge
Post by sharyn »
Not sure that title makes sense???
I am sure many of you already know this but just in case there are a few that don't. I thought I would share (gotta give something back)
Sometimes when the paper print is smaller that the item being printed you can get a permanent crease around where the paper sat. I have found if you tear the paper instead of leaving it as a sharp cut this eliminates the crease. Well it has for me!
Hopefully someone will find this helpful?
twinsgran
Post by twinsgran »
Thanks for that tip. I'll certainly give it a try. I actually avoid doing t shirts as I have never found a solution to this problem before.
Has thanked: 11 times
This is something we discussed on the forum before but is indeed a valuable tip :-)
sharyn
Post by sharyn »
Justin;73870 wrote:This is something we discussed on the forum before but is indeed a valuable tip :-)
I thought it may have come up before. Still glad some may find it helpful! I will go look for where it came up before I may learn something else! Thanks
roobear
Post by roobear »
Cool idea that mate, just like feathering.
