I just found out that my Heat Press is not heating up to what the display indicates so decided to take the controller apart to see if there was a way of Calibrating it - I expected to find at least a Pot to twiddle but nothing adjustable at all in there.
How on earth do they calibrate these things?
It's THIS one.
I have an intermittent problem with my Mug wrap, sometimes when it get to the idle temp when I hit the square button to tell it to go to working temp it cools down - I told them this but they said it was 'Normal' ! Obviously it is not normal but as it doesn't happen every time I don't want them to come and collect it (they did offer) as I will not be able to at least make some Mugs - it's ok, I am not losing mugs as at idle temp no sublimation takes place - it's just an annoyance.
I must admit though, I did make 20 mugs today and it didn't happen once.
It is obviously a broken connection in the wrap/blanket - if it comes to it I will strip it to find the problem myself.
Heat Press Controller Calibration.
Re: Heat Press Controller Calibration.
Those control units cannot be calibrated - they are set at the factory. The only way is to set your temp +10 degrees higher than you need.NikGrey;78405 wrote:I just found out that my Heat Press is not heating up to what the display indicates so decided to take the controller apart to see if there was a way of Calibrating it - I expected to find at least a Pot to twiddle but nothing adjustable at all in there.
It's THIS one.
Considering the offer of coming to collect it why not ask them to bring a replacement at the same time? I wouldn't want something that is obviously faulty causing me problems, wasted time, materials and 'money' through wasted stock.
"Those control units cannot be calibrated - they are set at the factory. The only way is to set your temp +10 degrees higher than you need"
The problem with that is I have this set to it's maximum, which is 430f so I can't. I will see what they say about bringing a replacement, they HAVE been good up to now as I had a bad CISS which they did replace.. ok, the new one was also not good but the gesture was there.
I replaced that in the end though, with my Shiny new Ricoh from BMS which I am most impressed with
430 degrees F is around 220 degrees C. Presumably your display is 30+ degrees C out if you're not getting a good print as 190 degrees C would normally be enough.NikGrey;78417 wrote:"Those control units cannot be calibrated - they are set at the factory. The only way is to set your temp +10 degrees higher than you need"
