Cameo Question...
Re: Cameo Question...
Hi Guys
For those of you who have a Cameo, can you tell me if it will cut 5mm foam board?
I have a job that requires 28 letters cut which are about 140mm high. Normally I would cut them myself but if a Cameo can do it then I may as well buy one to do it.
Any info would be greatly appreciated.
NikGrey
Post by NikGrey »
I just extended my Cameo blade fully, to No10 and the blade protrudes at most 2mm.
That will be a "no" then :-)
viccar
Post by viccar »
Thought these specs would come in handy
Maximum Cutting Area
12”x 12” (29.5 cm x 29.5 cm) with a cutting mat
12” x 10’ (29.5 cm x 3 m) with a lined media
Maximum Media Thickness 31.5 mils (0.8 mm)
Maximum Cutting Force 210 gf
SD Card Read only. 16GB, SD and SDHC compatible
Compatible Media Types
Vinyl, heat transfer material, cardstock, photo paper, copy paper,
rhinestone template material, fabric, and more
Interface USB 2.0 high-speed
Unit Dimensions 20.9” x 6.5” x 5” (53.1 x 16.5 x 12.7 cm)
Unit Weight 6.5 lbs (2.95 kg)
Shipping Dimensions 24” x 11” x 11” (61 x 28 x 28 cm)
Shipping Weight 11 lbs (5 kg)
Warranty 1 year parts and labor
socialgiraffe;78737 wrote:That will be a "no" then :-)
Definitely a "no".
GoldRapt
Has thanked: 5 times
Been thanked: 7 times
Post by GoldRapt »
Have a word with Harry at Edward Mathias http://www.edwardmathias.com/
Even the specs for a pro cutter like the Graphtec FC show limits of 0.25. But it depends on the down force capability....I think.
Personally at 5mm I think you might be talking laser cutter rather than knife cutter.
regards
Tony
-launching july/august 2026
