S21 Cartridge problem
Re: S21 Cartridge problem
Hi
I have a Epson S21 printer which i am using the CISS cartridges inside printer (not bottle feed). My black cartridge has all the sudden stopped working but the other 3 colours are working fine.
I have ran serveral cleaning processers but no joy ink is full in the cartridge so i know it's not the ink level
can anyone help me please?
Thank you
Thank you
Matthew
Can you check if the cartridge is holding a vacuum? Try pulling ink out of the cartridge when the outlet hole is sealed. Does a vacuum form? If not then the cartridge probably has an air leak and needs to be corrected or replaced.
Hi
Yeah i checked that cartridge it holds a vacum.
Matthew
Try putting in a normal ink cartridge - does that print? If not then the print head might be blocked. You could try cleaning this with a product such as nozzle rocket (or other print head cleaning solutions) if it does appear blocked.
Thanks i'll try that today. i'll let you know if it works
Matthew
I've decided just to buy new printer just got sx105 off ebay
Matthew
is that for sublimation??enviroprintuk wrote:I've decided just to buy new printer just got sx105 off ebay
yeah read few articles on net and it's ok for basic items that don't need lots of colours
Matthew
