Mug printing
Re: Mug printing
I have only just started printing on mugs and have had some success but also a lot of disasters .
I had problems putting the paper on the mug when it was hot as I found if I took too long it smudged and couldn't get it straight quick enough.
S I have been trying the method putting a cold mug in I heat it up to 180 and 180 seconds .This can work sometimes but then it doesn't it sometimes blurs in the middle at the bottom ,I tried using Teflon I'm not sure why but keep getting intermediate results.
Any help would be greatly appreciated.:frown:
Re: Mug printing
I think you misunderstand this methodI had problems putting the paper on the mug when it was hot as I found if I took too long it smudged and couldn't get it straight quick enough.
You don't have to heat printed mug up BEFORE you stick it in to the press.
just put transfer on cold mug. then put it in.
set your press to correct temp and time and off you go
Re: Mug printing
If you're based in Blandford then pop into our office during the week and Scott can talk you through the correct process for printing mugs.HELEN1234;91788 wrote:I have only just started printing on mugs and have had some success but also a lot of disasters .
Re: Mug printing
Those were the instructions I had ,I soon stopped that and now put my mug in cold then press the timer but the temp drops a lot and reaches 180 about 40 secs before the end.
Most of the time the first mug comes out fine its the next ones that can go wrong. I have been reading posts on here and they say you should leave your printed paper to dry ,I am not doing this do you think this is the problem?
Many thanks for your reply
Re: Mug printing
That would be great I only do this as a hobby so work until 3.30 at a school would he be available after then.
Re: Mug printing
We close at 5:30pm daily so best to call the office and make an appointment just to be on the safe side.HELEN1234;91792 wrote:That would be great I only do this as a hobby so work until 3.30 at a school would he be available after then.
Re: Mug printing
Thank you I work in Wimborne so not far to come I will phone to make appointment .
Thank you very much
Thank you very much
Re: Mug printing
Getting the right pressure against the mug is essential, but the blanket should just curl round the edge of the mug with light to medium pressure. A lot of mugs can be misshapen and I have had that exact problem with blurring. What mugs were you using?HELEN1234;91788 wrote:.This can work sometimes but then it doesn't it sometimes blurs in the middle at the bottom ,I tried using Teflon I'm not sure why but keep getting intermediate results.
180/ 180 seconds is a guideline and will depend on your mug press. Some of my presses are set to 195 degrees for example.
Re: Mug printing
Hi Helen,
How did you get on with this? The mug press will always drop in temp when you put the mug in. You need to wait for the temp to get back to the required level before you set the timer. The mug press should have the function on to allow this.
