Anyone else doing 3D ipad mini cases? Can you get yours to fit on cooling? Tried five times from two different suppliers and they all shrink beyond belief on cooling and after being slightly oversized before putting in the press, end up about 5mm too small and pop off the dummy ipad on cooling. Tried cold water, tried natural cooling with weight on it, and am getting the heating mould very hot before pressing. Can not stop it shrinking.
thoughts?
ipad mini 3D sub problems
Re: ipad mini 3D sub problems
get a dummy ipad mini first...if that dont work change your mold - cause some can be OFF slightly size wise...dont take much - trust me...been there done that
Think I've solved it reduce the heat and increase the time
sent using tapatalk on my Note4
