Multiple Printer Setup
Forgetful8
Re: Multiple Printer Setup
Post by Forgetful8 »
Hi guys,
Just curious as to how people have their printers setup.
Obviously, the easiest answer is 1-printer, 1-port. But that's a little impractical for me!
I've tried one of those switched USB Hub thingymujigs...despite saying printers in the ad, the laptop doesn't pick any up. It will work with the Cameo though.
So short of having to have a dedicated PC in the garage with a million USB ports (alright...slight exaggeration...), anyone got any other suggestions?
I'm currently down with a pretty serious case of man-flu. So you'll forgive me if I've missed anything obvious.
(My dearly beloved thinks I should shut-up and take a dose of man-the-f...chuff-up, apparently it's only a cold...)
[CENTER]A bored sailor is a mischievous sailor...
Boy, am I bored!
James990
Post by James990 »
All my printers are networked, so I can print from any computer, which I have a number dotted arround the place as well as my laptop. In fact I have just installled another printer to the network, which already is picked up by all the computers!
James
Forgetful8
How have you gone about networking the printers?
I know the Ricoh's all have an ethernet port on them...but other than that, I'm not sure where to go?
Boy, am I bored!
You need an Ethernet switch. Grab yourself something like this
https://www.currys.co.uk/gbuk/computing ... display~RR
You plug one port into your router and the other ports into the Ethernet ports of your network printers. You then have access to multiple printers.
James990
Post by James990 »
Or if your printer(s) is wifi enabled, sorted!
Customprintwales
Post by Customprintwales »
wifi is an easy solution. I have 4 printers connected up to my computer. ! is through usb and the other 3 are connected with wifi.
The only issue I had is with running 2 Epson XP-900s, it's a bit more of tweaking and playing around to make sure the right computer driver is used with the right printer as one is pigment dye for posters and prints and the other is my back up A3 sub printer.
I don't believe the Ricoh and Sawgrass printers are WiFi enabled.
Forgetful8
Customprintwales;130777 wrote:wifi is an easy solution. I have 4 printers connected up to my computer. ! is through usb and the other 3 are connected with wifi.
I know there's a bit more work in using multiple printers of the same make/model
UK Printed Mugs;130778 wrote:I don't believe the Ricoh and Sawgrass printers are WiFi enabled.
Correct - no wifi loo
Boy, am I bored!
You mentioned the laptop not picking up the USB hub? Just a quick thought, was this hub powered or non-powered? This can make a difference.
logobear
Post by logobear »
nearly all printers on network.
get a powered usb hub to add more to your laptop, or better still, buy a desktop pc with more grunt and lots more usb ports.
While at it, definitely get an extra screen, - at least 1 extra !
Users browsing this forum: No registered users and 15 guests
