I did it!
A place to discuss......Embroidery!
mrs maggot
Re: I did it!
Post by mrs maggot »
that is great that you have PE Paul, there is a lot of help out there for it, Techno babe https://www.facebook.com/technobabeinc/ does some great PE videos.
I love having my big hoops on my PR as well, but I am amazed at the size of some of the new home table machines (the ones that look like a normal sewing machine)
The key to the PR's is the daily hook oiling, they are a great workhorse. be prepared for a shock at the servicing costs, each of the little felt pads and there are 2 per tension dial are over £5 !! make sure you cost in the maintenance with your prices.
you will be hooked, I sat and watched mine for hours when I first had it, it is like watching magic just appear.
Re: I did it!
mrs maggot;145683 wrote:that is great that you have PE Paul, there is a lot of help out there for it, Techno babe https://www.facebook.com/technobabeinc/ does some great PE videos.
This is one thing That i didn't consider yet. Service.
How often is it done? and how much does it cost to have it fully serviced?
mrs maggot
Re: I did it!
Upwards of £300 per service Paul. You need to find someone good near to you. and cherish them, as you need to get the machine to them, some of the companies offer a collect and deliver service, but of course that is added on. There is a certain amount you can do yourself, which will be in your book, but the main, all covers off services start around the £300 mark and are done on so many stitches. To give you an idea, the felt pads in the tension discs, 12 in total 2 per tension head are over £5 each! I have written to brother to ask how they can justify it. I think as the prices of machines is so cut throat the spares are where they have you by the short and curlies.
Re: I did it!
thank you for that!
I have brother agent 25minutes drive from me so I can use them. But I got my machine from http://woodseatssewingmachinesshop.co.uk
and thats a a,5hours drive. But I don't mid to have a nice drive once a year or so, for a good service. May book a night in the hotel and do some site seeing :)
Do you have any experience with patches? I would do with some tips on what will I need to start making them.
PS. Thank you for recommending Techno Babe!! I learned so much already! :D
mrs maggot
Re: I did it!
Buy the best stuff you can out there for patch making, and take your time, is the best advice. Make sure you are using good threads, use a good supplier https://www.gs-ukdirect.com/ is a good place to start.
Earl Smith
Re: I did it!
Post by Earl Smith »
Hi, daily hook oiling? No. Every second time you change the hook. Daily is not enough. Just a drop though as you will clog up the path of the thread in the bobbin case and get thread breaks.
mnporter2001
Re: I did it!
Post by mnporter2001 »
Good luck with this new venture [MENTION=4]Paul[/MENTION]
Mark
Custom Gifts www.mugsaway.co.uk <--- A work in progress!
Re: I did it!
mnporter2001;145755 wrote:Good luck with this new venture @Paul
Mark
Thanks Mark.
There is two options there. I will love it and i will be hooked in to it, or throw it through the bloody window :biggrin:
Earl Smith
Re: I did it!
Patch material. I buy Twilly from Gunold. Its made for patches. A german supplier could be of use to you if you need some other colour is https://www.schneider-wohlenberg.de/index.php/en/
Re: I did it!
Question for you [MENTION=1332]Earl Smith[/MENTION],
In every video I watched on YT I can see that people embroider bit of a patch, cut it out and THEN do the last satin stitch. Why is this?
Can you not do full patch at once and then cut it out? Hope this make sense for you :D
