Can anyone do Rhinestones?
Re: Can anyone do Rhinestones?
I realy need to see how many stones i will use. I got something like 4000. hope it will be enough. ca you provide this graphic in vector? so I could tell you exact cost.
Kaz
Post by Kaz »
I've got pink rhinestones, if that helps, also got lilac, green, silver, gold, red, blue.
Kaz
Post by Kaz »
And they should travel fine, as long as they have cardboard protection on either side to keep them flat
Stitch Up
Post by Stitch Up »
Rhinestone patterns travel really well in the post as they're sandwiched. :)
Angie does lots of them and enjoys it!
AdamB
Post by AdamB »
Kaz;23319 wrote:And they should travel fine, as long as they have cardboard protection on either side to keep them flat
If you have Pink ones Kaz, are you up for it please? I will send you the info via PM to look at if you fit it in?
Kaz
Post by Kaz »
No probs Adam, send away
AdamB
Post by AdamB »
Kaz;23380 wrote:No probs Adam, send away
PM sent Kaz :-)
fredster
Post by fredster »
just a quick question to those who do do rhinestones...can you add them over the top of vinyl ?
thinking of giving them a go myself as i could sit and fiddle with them at work of an evening... lol
draig
Post by draig »
Not really, the glue needs something to hold on to. If you want to add rhinestones to a vinyl print it's better to cut holes out where you're going to place them when cutting the design.
draig
