When to pull the paper off
JMugs
Has thanked: 9 times
Re: When to pull the paper off
Post by JMugs »
As it says.
I cocked up a stein this afternoon. I took the stein out of the press pulled the paper off but not smoothly and smudged it!
Now I have seen lots of variations, one of which was leaving the paper on and placing the mug in the bucket, only taking the paper off after it had cooled. At the time I thought how odd, however this afternoon I wondered if it was such a daft idea. Anybody else tried this, am I the only hamfisted numpty?
Throw your ways in the pot and see if there is a common method, and comment on the above idea.
Cheers me ansoms.
Janners.
You get the hand of whipping the paper off quickly without burning the ends of your fingers off :-) You can also leave a small tab or double the tape over so you have something to pull. In my experience you can indeed leave the paper on whilst you dunk the item but it's a little messy pulling it off and the tape shifts easier whilst warm.
mgibbs
Post by mgibbs »
I always dunk with the paper on.
It's not in the water long enough to go soggy.
Mark
jennywren
Post by jennywren »
I do the same as Justin, the trick is pull the paper away from the stein, it might not have been that the paper might not have been on tightly enough and got smudge in the press, and not in the pulling of the paper
RogerC
Post by RogerC »
dunk and pull every time.....:biggrin:
WorthDoingRight
Post by WorthDoingRight »
JMugs;48388 wrote:I took the stein out of the press pulled the paper off but not smoothly and smudged it!
Are you sure it wasnt your eyes that were blurred and not the mug smudged? I wonder if prehaps you had been drinking too much of the contents fit for the Stein :rolleyes:
bigj2552
Post by bigj2552 »
WorthDoingRight;48453 wrote:Are you sure it wasnt your eyes that were blurred and not the mug smudged? I wonder if prehaps you had been drinking too much of the contents fit for the Stein :rolleyes:
LOL...i,ll need to test your stein for consitancy sir before i sell it to you....be back in 2hrs......hic...hic...yep, no hic....leaks in it ....hic....sfine...sall gud...hic....thatl be £11.99 ...hic..please...
Reg
Post by Reg »
I found using a silicon wrap stopped the blurring on steins.
jennywren
Post by jennywren »
I to use a silicon wrap, Didn't know it stops blurring, I use it to stop ink transfer between mugs
Reg
Post by Reg »
I had 2 steins blur when I first tried them so I tried a silicon wrap as I thought it might be the ribs on the stein reducing the pressure on the paper and haven't had the problem since.
