Hi Viz shirt printing problem
Re: Hi Viz shirt printing problem
Hi ... i bought 6 Hi Viz tops from BMS and have an issue with them ...
I have tried ringing BMS but got their answerphone again ..
I printed successfully on one top M size and then attempted to print on another size M top. The second Hi Viz wouldn't take the image ... it was very very faint indeed.
I reprinted another fresh sheet thinking it was that and again it wouldn't take it ...
After further inspection of both tops i could clearly feel the successful top had a softer smoother finish to the surface while the failed one was a much rougher feel.
Anyone from BMS could you please let me know your thoughts on this issue as i cant afford to let customers down while in shop ...
This has to be a problem with the material not accepting the inks ...
Regards
Keith
Regards
Keith
i have just tested the failed print on a test Hi Viz i did last week which i keep for test prints and it worked 100% .. this certainly indicates the failed Hi Viz is or has some kind of different makeup to the cloth ...
I have quite a few Hi Viz shirts left and just hope they don't fail .. Gulp
If you want to cover up any mistakes with a digital print, let me know and I can mail you the vinyl. Can leave a white block behind it.
I just assumed hi-vis wouldn't take a dye sub? Do you have a photo of a successful one?
J.
J.
Day Out Photography
www.dayoutphotography.co.uk | facebook.com/DayOutPhotography | twitter.com/DayOutPhotos
m. 07817 118 717
m. 07817 118 717
Hi Johnny
Hi Vis sublimates really well as they are normally 100% polyester, you just obviously have to be aware of the colour change to anything you print (i.e. yellow will not show at all).
Volusian
I have always purchase the YOKO range from BTC. Very cheap and a good range of colours in the vest. Hi Vis yellow from BTC are £1.30 each plus £5.99 delivery (all plus VAT) on orders under £250.00
Volusian
do you use same transfer to print more then once?Volusian;73073 wrote:Hi
Keith
Replied earlier to your pm. If we are busy on the phones then please leave us a message for someone to call you back. We can't guarantee same day call backs as staff are busy but will try our best.Volusian;73073 wrote:Hi ... i bought 6 Hi Viz tops from BMS and have an issue with them ...
Regards
Keith
I have a job which just came in, the fella brought me 12 Yellow High Viz vests - they are 100% Poly.
I want to use Metamark metaTex Transfer Flex. the problem is the application guidelines state 170c and I am thinking this will melt the material.
Any thoughts?
I suppose the only way is to do a test..
Any thoughts?
i use Textile vinyls daily and fix at 160c for 15secs ... both on polyester and cotton ... and Hi Viz tops ... never had any problems
Dave271069
TMT Do a vinyl which press at very low temperatures,i think its called magicflex but i may be wrong,
Printed loads at 180c for 50 secs and never had any problems. Get my vests from a clothes supplier direct. As said the colours never turn out correct but as long as customer sees a printed one they normally say it will do.
Ray
Ray
Users browsing this forum: Google [Bot] and 4 guests
