galerion;88666 wrote:On your working one have you ever had your fan shut off while your timer is running?
watch for a proper seal when using these machines - read on -
started machine and vaccum....all's well. then 1 min into sublimating, the dreaded farting sound from the machine....
i knew it was the seal.....it cant have ruined another silicon seal...
let machine finish..took out case, half baked = bin....
looked to see if the silicon had small tear anywhere....nope...
- fired it back up....same again...WTH
opened it back up.....you know what it was ?...a sodding HAIR.....yep, a single hair....i said, no, cant be just that....fired it back up and another case....PERFECT
unreal a hair can stop the seal from working
answer to your question my friend - the other machine's fan had NEVER stopped when cooking a case until 2 days ago.....half way through, fan stopped...no point in carrying on...stopped, case buggered...switched off machine thinking another condenser away, but it fired back up again....phew !!!!
i am ordering 4 of these condenser things that drive the fan for backup....just in case its a (another) weak spot in the build :rolleyes:
but, on the whole, now we know how to work this thing setting wise, it gives great results....mugs incl !
just to master the full wrap for the mugs around the handles and we got there - like someone else said, i to can get the print onto the actual handle, but need to find a way to get pressure onto it - print is to faded due to not enough weight behind it - thats this weekends job, if we got time
