Hi, I've got a 3d vacuum heat machine, The products I'll be doing will be mugs, Phone cases, plates and shot glasses.
I am just after some general advice please? I've watched so many videos and they all seem to be different.
1, Do I need to heat up the products before I set the timer going? (do I warm up the product with the picture attached)?
2, Do I attach the picture when the ink is wet or dry?
3, Do you leave to cool before removing the sub paper?
4, do I print straight from photoshop or do I change it back to a jpeg and print it straight through the printer software?
All advice will be greatly received thank you.
General sub advise please?
Re: General sub advise please?
No, but should be room temperatureDo I need to heat up the products before I set the timer going? (do I warm up the product with the picture attached)?
Dry, otherwise it will smudgeDo I attach the picture when the ink is wet or dry?
Personal preference, some people are dunkers, others are leavers, it will all be down to your exact set up.Do you leave to cool before removing the sub paper?
