What are the Advantages/Disadvantages of Using Dye Sublimation against HTV
tuz
Re: What are the Advantages/Disadvantages of Using Dye Sublimation against HTV
Post by tuz »
Also, is there any differences in the choice of Heat Press.
HARDWARE
Roland Camm-1 GS24 Vinyl Cutter
Klic-N-Kut Element Vinyl Cutter
SOFTWARE
Inkscape - Xara 3D Maker - Easy Cut Studio - Make The Cut
pw66
Post by pw66 »
The heatpress needs to have a consistent temperature both accross he entire platen and be able to hold that temperature for the duration of the pressing. You ccan't always guarantee that from a cheaper press.
HTV is great for simple logos and text on workwear and general garments. Sublimation is imited to white/light polyester but you can print full colour complex designs. There are also plenty of other substrates you can sublimate onto.
