Help needed mh721 cutter plotter
wayne
Re: Help needed mh721 cutter plotter
Post by wayne »
Hello all
I have a major problem with my mh721 the usb port got damaged (snapped off on the inside) so I have installed a serial port on my pc and I am now using the serial port but the cutter can not be found by the software, i am using flexisign and signblazer please help
cardman
Post by cardman »
u got your setting right for serial port as i heard they can be a right pain to setup
Also make sure u got it set to com 1
wayne
Post by wayne »
Thank you for the reply I have tried all the ports inc com1 still no luck
are you sure is under com 1 on your pc?? if so did you check in the production menager in flexi com is changes as well?
whats mh721??
wayne
Post by wayne »
Yes made sure both settings were the same mh721 is a cheap cutter plotter
but it must have a name :rolleyes:
uscutters one?
wayne
Post by wayne »
thats the one
is it set like this?
and also have you got this thicked here?
any error msgs??
wayne
Post by wayne »
what software is this? we have v8.1 ?
this is flexi10 but manager looks same in previous flexi
